Re: Throttle Linkage Adjustment on an H
Posted by John in Ct on December 02, 2005 at 15:48:10 from (69.24.45.5):
In Reply to: Throttle Linkage Adjustment on an H posted by Randy_NE on December 02, 2005 at 12:26:10:
I am not sure if we did mine right but I will tell you what we did. On the throttle handle the hole was a little worn so we put a brass bushing in ( drilled it out some so a bushing could fit) there to tighten it up and built up the part that goes in the saw tooth with weld. I replaced the spring that holds the handle in place. I replaced the circle saw tooth part with a NOS one. My rod had some wear where the springs are so we built it up with weld and ground it flush. We put a bushing in that crank thing that moves on top of the head ( I forgot what it is called). It was a very tight fit and had to use a clamp to press it on. Next we replaced both springs and that square block thing (nos). I ended up with VERY TIGHT linkage and it seems to work great.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
