Some of the time it is a bad seat, some times it is a loose seat, Sometimes the float is filled with gasoline. Sometimes it is the float rubbing on the bowl, Sometimes it is the needle getting stuck in the seat bore. I would try to test by removing the bowl, and (as someone brilliantly noted on this site) put a clear shallow bowl or jar under the carb up around the parts substituting for the cast bowl, and turn on the fuel. If it does flood higher than the setting, it is clear why. The only exception is rubbing on the bowl. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
