Farmall Tractors Discussion Board
Re: '49 Farmall cub 6 volt to 12 volt change over
Posted by The Red on January 01, 2000 at 08:37:13 from (12.75.197.180):
In Reply to: '49 Farmall cub 6 volt to 12 volt change over posted by Jim Hook on December 31, 1999 at 16:41:39:
Jim if you are leaving it 12 volt positive, just make sure to replace the light bulbs and stick a resistor in the coil line so the coil is getting 6 volts. Other than that it should wire the same as it is now. Starter will simply spin faster.
If you are going to 12 volt negative, swap the wires on the coil and the ampmeter if you have one.
Post A Followup
: Re: Re: '49 Farmall cub 6 volt to 12 volt change over
