Re: no steering on cold startup
Posted by JJK on December 02, 2005 at 19:20:35 from (216.189.131.91):
In Reply to: no steering on cold startup posted by skip on December 02, 2005 at 17:58:17:
You can try to change the hyd. filter first to see if it helps but I have a feeling that the pump is getting weak because it shouldn't have any trouble running at 30 or even 10 degree's. Might be a little stiff but should still work. I hope the reman pump is right from Case IH and not an aftermarket. I've had the best luck with those than anything else. I also suggest completely going through the MCV if you put a new pump on just to make sure the spools aren't hanging up and any junk that can be floating in the system is cleaned out. Also if the pump doesn't prime up after repair you can remove the 5/8 hex plug on the right side of the MCV,(little messy) start tractor up and shut off as soon as oil shoots out, and make sure you keep out of the way of the oil spray. Install plug and your good to go.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
