Re: Farmall M radiator gurgling
Posted by El Toro on December 03, 2005 at 04:10:30 from (152.163.101.13):
In Reply to: Farmall M radiator gurgling posted by SoDak man on December 02, 2005 at 21:30:25:
I would check that thermostat to make sure it's opening & isn't stuck closed. Place in a pan of water and heat to see if it will open a around 180-190 degrees. Hal
PS: Was your antifreeze mixture 50/50? Your radiator may have frozen if you didn't have enough protection.
