Re: no steering on cold startup
Posted by the tractor vet on December 03, 2005 at 06:23:30 from (4.124.77.169):
In Reply to: Re: no steering on cold startup posted by skip on December 02, 2005 at 21:57:56:
THere is and AFTERMARKET spring kit for the mcv and you will need a seal and gskt pkg. if you are going that way but i would do some testing before i would spend money that may not be needed and i know you do not have a flow rater to check the pumps out put but it may be in your best intrest to have it done by the dealer it's real easy to spend money and still not solve the problem . We all can give you information on the what if's and maybe's but with out running the tests it is just guess work .
