Re: no steering on cold startup
Posted by Aces on December 03, 2005 at 12:06:26 from (65.54.154.46):
In Reply to: no steering on cold startup posted by skip on December 02, 2005 at 17:58:17:
Skip When I worked on these tractors if I could not use the flow rater. My test was remove the pump and with the pump pressure port full of oil turn the pump with one hand and if I could hold my thump on the pressure as I turned the pump the pump was bad.
