Re: Gas tank for 656
Posted by El Toro on December 03, 2005 at 13:36:51 from (205.188.117.73):
In Reply to: Gas tank for 656 posted by Joel B. on December 03, 2005 at 12:15:37:
You could have that tank relined or find a good used tank. Have you tried Case/IH? Here's a website for tractor salvageyards. Hal
http://www.epartdirect.com/index.php?t=fc&s=s
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
