Re: 656 Remote Rebuilt and still Leaks
Posted by K.B.-826 on December 03, 2005 at 18:06:55 from (209.163.43.7):
In Reply to: Re: 656 Remote Rebuilt and still Leaks posted by FormerlyPaMike on December 03, 2005 at 14:10:26:
Mike, good move buying the entire piston/o-ring assembly. Even so, you may have cut the o-ring. I like to lube things like that with STP for reassembly. Did you replace the two o-rings that go around the outside of the spool? I also believe there's an o-ring between the spool and the detent ball holder that threads into the rear of the spool. I can't remember how far the detent piston is supposed to stick out of the spool.
