Posted by pete 23 on April 08, 2009 at 10:48:45 from (173.87.1.12):
In Reply to: Magneto timing posted by Slappy on April 08, 2009 at 06:26:22:
The impulse is supposed to be set to snap at 5 degrees after top dead center. All H and M's have that second mark right after tdc on the front pulley and it is the 5 degree mark, this gives you a 30 degree advance while running and it also accounts for a not very smooth exhaust sound at low idle with certain combinations of heads and pistons etc. Not sure if the little tractors flywheel were all marked that way or not.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
