Re: lookin at buying a 886 black stripe ? torque
Posted by the tractor vet on December 04, 2005 at 07:24:24 from (4.124.70.115):
In Reply to: lookin at buying a 886 black stripe ? torque ampl posted by tugboattim on December 04, 2005 at 07:04:49:
well the way to tell if the T/A is half desent is to get it out where ya can get her in high range and in either 3rd or 4th full throttel and start riding the brakes to bring her down to around 1500rpm and pull the stick back but be ready on the clutch if it stops dead in her track because it just may make a big lurch . And check and see how much ware is in the steering cylinder and tierod ends look for milky oil in engine and trans and rear end , look for oil in the radatior . Check shift linkage and any oil and hdy leaks ware on the three point . the rest is up to you.
