Re: Farmall H cylinder head studs
Posted by Janicholson on December 04, 2005 at 16:00:27 from (66.173.50.118):
In Reply to: Farmall H cylinder head studs posted by Ed Gilliland on December 04, 2005 at 11:15:08:
If the head gasket is good, there should be no coolant there. Since there is, I assume you are replacing the gasket.
If the head is cracked into the stud holes (quite possible) there is no fix, you need a rebuilt, new, good used head.
If the head/block is pitted near the sleeves, they can be resurfaced (the head more than the block) to smooth out the pits.
Thorough cleaning and use of a thin film of JB weld, followed by flat sanding with 220 paper might also help the pitted area to seal if resurfacing is not happening.
Good luck, JimN
