Re: 504, cold weather and me
Posted by T_Bone on December 04, 2005 at 17:58:18 from (4.240.90.243):
In Reply to: 504, cold weather and me posted by Sloroll on December 04, 2005 at 16:16:44:
Hi Sloroll,
I think I'd grab some 1/2"plywood, 1-1/2" angle iron, a fan and heater housing out of any used car, some plexiglass and make my own. That way it will custom fit what you put it on.
If you use the angle iron to line the six section pieces then bolt each section together then you could take it off at the end of the season and save it for next year but it would store flat so it wouldn't take up hardly any room.
Add a couple ball valves on your cooling system with garden hose quick disconnects to the heater coil. Just shut off the ball valves and pop the QD's and drain the heater coil for storage.
Add a fan relay and switch and you have cab heat and defrosters with some simple 2" round duct work.
T_Bone
