Re: IH oil
Posted by Pale Rider on December 04, 2005 at 20:19:35 from (207.200.116.203):
In Reply to: Re: IH oil posted by PAULIH300 on December 04, 2005 at 06:55:18:
It makes no difference WHO makes IH oil as long as it is made to IH specifications. I have never heard of seal swell additives or their affects on leaks. I DO know however that some oils with very high detergents such as Caterpillar oil will cause an engine that had never experienced lead to suddenly begin to do so since the detergents remove the oil and accumulated sediments around the gaskets. I have seen it more than once.
