Re: What do I use to take this out?
Posted by red state on December 05, 2005 at 16:14:29 from (170.215.20.42):
In Reply to: What do I use to take this out? posted by TKN on December 05, 2005 at 15:11:05:
Measure the square, I believe it may be 5/8 not sure, then go to your local welding shop and ask them for an 18 inch or so piece of COLD rolled solid square stock, have them bend a 90 degree in about 2 or so inches. Use cold rolled vs hot rolled because of the hardness, Then you have a tool for that odd size plug. I had this done a couple years ago, i think it cost me about 6$. Hope this helps
