Re: What do I use to take this out?
Posted by Hayfarmer on December 05, 2005 at 18:49:16 from (66.243.239.207):
In Reply to: What do I use to take this out? posted by TKN on December 05, 2005 at 15:11:05:
So question is why was a plug with this size hole used instead of 1/2 or 3/8? In the modern era manufacturers have come up will all kinds of heads on bolts and screws so you can't take them out with a normal screwdriver and have to take it to a dealer. But why would IH have done this back in the simpler days?
