Re: splitting a super m
Posted by Nat on December 06, 2005 at 06:28:55 from (64.80.108.52):
In Reply to: splitting a super m posted by redpowerman on December 05, 2005 at 14:54:21:
I&T manual only goes so far. Basically, it just says, "Remove everything that needs to be removed to split the tractor, then split it." Not for the mechanically challenged.
A typical "split" is done at the bell housing, to separate the engine from the rest of the drivetrain. You'd split it here to replace the clutch, or overhaul the engine. You'd probably want to split it here even if you do split the tractor again behind the transmission (can you even do that on a regular Super M?). The smaller pieces will be easier to handle.
Really, where you split it depends on what you want to do.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
