Re: sticky needle valve
Posted by RustyFarmall on December 06, 2005 at 10:24:15 from (216.248.75.155):
In Reply to: Re: sticky needle valve posted by gene bender on December 06, 2005 at 10:10:21:
I tried that "small tap" trick and ended up tossing that particular needle valve. Some of the rubber tips are good, some are not, and it doesn't make any difference who made the kit or who you bought it from. I prefer to re-use the all steel valves if they will clean up good.
