Re: Super M hard to start
Posted by old on December 07, 2005 at 09:15:15 from (207.69.137.35):
In Reply to: Super M hard to start posted by Jeff Jackson on December 07, 2005 at 09:01:41:
12 volt or 6 volt?? Check all connections starting at the battery and make sure there clean tight and brite. Also does it have the right size battery cables, if it has auto type cables there half your problem. It need to have 0 or 00 battery cables. How good is your spark at the plugs?? IF its not a good blue spark theres part of the problem. You also may have a starter dragging which will also cause slow engine turn over. Just a few things to look at. I'm no expert but I do take a lot of dead tractor and make them run.
