Re: Farmall 460 coil
Posted by rvirgil_KS on April 08, 2009 at 11:19:08 from (204.120.12.200):
In Reply to: Re: Farmall 460 coil posted by bc on April 08, 2009 at 09:23:30:
Good question and observation.
The resistor bypass start circuit is not used on all 12 Volt systems.
Your NAPA 12 Volt coil would operate on full 12 volts (no resistor). As you observed one terminal goes to distributor other direct to ignition switch. This coil is not used with a resistor or in a bypass circuit.
Some refer to a 12 volt coil as "internally resisted". My understanding is that most 12 volt coils actually have no internal resistor, rather the primary is wound for 12 volts. (But I know there can be exceptions to every assumption.)
Bob
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
