Re: W-6 part,s
Posted by El Toro on December 07, 2005 at 16:32:08 from (152.163.101.13):
In Reply to: W-6 part,s posted by kirk C, on December 07, 2005 at 09:02:49:
Charge the battery, clean & tighten battery cables. Check alternator for charging after you have the tractor running. You should be able to see where your alternator bracket should go. It should be slotted too for adjustment. If you don't think you can fabricate a bracket check with your local metal shop. That's a piece of cake for them. Hal
