Re: alternator pulley for Farmall B tractor
Posted by gene bender on December 07, 2005 at 22:06:29 from (66.43.221.81):
In Reply to: alternator pulley for Farmall B tractor posted by sommer on December 07, 2005 at 07:02:08:
If you are restoring the tractor why are you using an ALT? Better make sure the pulley is smaller than the one on the fan or you wont have enough rpms to do any good as this happens a lot.
