Re: Wow....That was SCARY!
Posted by RayP(MI) on December 08, 2005 at 17:05:10 from (216.46.213.124):
In Reply to: Wow....That was SCARY! posted by Gary NY on December 07, 2005 at 20:10:27:
Couple years back, I was plowing with my Farmall 200 when the starter switch shorted to ground through the starter pull rod attached to the headlight bracket. Managed to get to battery disconnected, but not before getting serious burns on my hand, and destroying the battery terminal. Now, with a new switch on the starter, the pull rod is also insulated from the headlight bracket with a plastic tab, to prevent the rod from conducting electricity back to ground.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
