Re: Re-Converting Alternator to Generator?
Posted by CNKS on December 09, 2005 at 08:13:00 from (204.249.178.138):
In Reply to: Re-Converting Alternator to Generator? posted by David Kronwall on December 09, 2005 at 03:53:45:
On that particular tractor with, as Hugh says, the alternator hidden under the hood, I would leave it be. My M has an alternator, but if it had a generator, I would probably leave it alone, also, but I might convert the generator to 12 volts, as six volts is marginal for an M. On the other hand to purists, the A,B,C, etc likely don't look right with an alternator, regardless of the improved reliablility.
