Re: b250 and a snowblower
Posted by EricB on December 09, 2005 at 08:48:00 from (216.209.84.11):
In Reply to: b250 and a snowblower posted by buggsy on December 09, 2005 at 08:19:31:
Buggsy:
I have a B250 and a 6ft blower. It runs fine but there are a few things to watch for.
It seems to need full throttle to do a good job. Snow is weird stuff. The moisture content will affect how well it blows. Slush won't go through anything, regardless! I also find that a good depth seems to blow better than just an inch. Sort of like baling hay! Make sure your driveway is clear of stones, or let a base build up before you start using your blower.
Good Luck!
