Re: SC Just release bearing
Posted by farmallhal on December 09, 2005 at 12:53:49 from (64.24.35.17):
In Reply to: SC Just release bearing posted by Keith-OR on December 09, 2005 at 09:29:37:
Thanks Keith for the info. I checked my parts catalog and part no. 361292R91 is one of three optional bearings listed for tractors equipped with a hydra-creeper attachment. The other two are 18567D and 55212D. You should take the old bearing and retainer with you to be sure you are getting the right part. The part catalog doesn't show just a bearing for tractors without the hydra-creeper attachment just the retainer assembly which contains the bearing. I hope this is in fact correct as it would certainly be less expensive. Good luck and let us know. Hal
