Re: wheel weights? Are they worth the effort?
Posted by Allan in NE on December 10, 2005 at 05:35:44 from (148.78.243.26):
In Reply to: wheel weights? Are they worth the effort? posted by lekander883 on December 10, 2005 at 04:37:01:
Lek,
Depends on the size of your tractor.
If you are using a small outfit, I'd think that is not nearly enough weight to be moving bales; you might need two or three sets of wheel weights and fill the tires with calcium on top of that.
If it is a larger tractor, perhaps you don't need any weight at all.
It takes weight to move weight.
Allan
