Re: Hyd on 450
Posted by Funnyfarm on December 10, 2005 at 11:13:54 from (209.176.194.8):
In Reply to: Re: Hyd on 450 posted by Wheaty on December 09, 2005 at 10:12:24:
I was on the site looking for other info, and saw this. I just spent alot of time on my hydraulics this summer. I would loose pressure when the system heated up while cutting hay.
On my 450 the reservour is on the right hand side just below the hydr handles. It is a square tank, and at the bottom there is a two bolt eye shaped cover. This is where my screen is. The one was PLUGGED so bad it had collapsed. i could not find a new one, but fortunatley found one used that cleaned up good.
For filling and checking the level of the fluid there is what looks like a standard 1/2 pipe plug. The dipstick is on this plug, I keep mine "finger tight" and check it often.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
