Re: Hydraulic Additive
Posted by Janicholson on December 10, 2005 at 11:48:34 from (66.173.50.150):
In Reply to: Hydraulic Additive posted by PAULIH300 on December 10, 2005 at 11:17:08:
I know of no additives that allow use of contaminated fluid. The best solution is heat of use, or heating the oil in an open container to boil out moisture. Transmission/hyd. oil in winter never gets warm enough to drive water out. Another solution might be a filter (bypass type) I found a sight for them, (often used on machine tool hyd. systems with higher specs than any ag unit)
They are known to work, but I don't know the cost. They are modest in size and tidy in installation.
http://www.filtroil.com/features.shtml will find one supplier, I am not endorsing this brand, just indicating a potential solution.
JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
