SC clutch return springs.
Posted by Keith-OR on December 10, 2005 at 16:38:31 from (207.200.116.203):
I sure am glad that release bearing does not need to rely on these springs #17 part #355795R2. They are worthless as far as pulling bearing away from clutch. Even with the clutch pedel unhooked they would not pull bearing to the rear. And everything is cleaned up and oil so there in no binding of the parts. I even went so far as to put in stronger and heavier springs. Has anyone else run into this with these springs.... Could have left them out for no more good than they do!!
Keith & Shawn
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
