Re: Nissan Alternator for my H
Posted by Delbert on December 11, 2005 at 06:03:13 from (65.164.58.16):
In Reply to: Nissan Alternator for my H posted by DelMN on December 11, 2005 at 05:23:41:
Try salvage yard most likly they would have one that would work. also if you would use your old braket for your gen and add a braket to it for the alternator you can use a g m alternator. And the same bracket that holds gen. Also you will need to use the old pully off the gen to adjust the belt. On the g m alternator you will need to drill a hole and tap it to hold pully on just like the gen. Theres not alot of room but will work. Either a three wire or a single wire.
