Re: Gas Farmall Noise Levels?
Posted by RustyFarmall on December 11, 2005 at 09:28:53 from (199.120.81.210):
In Reply to: Gas Farmall Noise Levels? posted by SAm in NS on December 11, 2005 at 08:08:45:
It has to do with amount of compression the engine has. The older distillate and kerosene engines had relatively low compression and were pretty quiet. The higher compression gasoline engines would talk a little bit, and if someone has installed the aftermarket stepped head or domed pistons, this will raise the compression even further, and you can usually tell just by the sound which engines these are. They definately have a distinctive bark to the exhaust note and just sound like they are ready to "git-er-done".
