I need 544 Row Crop lift parts
Posted by ih544D on December 11, 2005 at 15:29:44 from (69.241.44.20):
Anyone know where I can find either good used or new parts for the position control on my 544. The local dealer said they can't get the shaft I need. It's the shaft from the position control lever on the driver's right to the hydraulic controls under the seat. The part numbers I need are:
Shaft: 376060R11
Ret Nuts (2): 376063R1
Spring: 378067R1
Snap Ring: 378066R1
Seal: 383133R91
If I could find the whole assembly from a parts tractor, I'd take that too. Mine is a 1969 model. Thanks for your help.
