CUB 154 LOW BOY
Posted by VETTE on December 11, 2005 at 17:17:45 from (209.240.205.63):
I TRADED FOR A 154 CUB LOW BOY THAT HAD A BAD CLUTCH AND T/O BEARING. IT HAS A FIVE FOOT MOWER UNDER IT SO I THOUGHT WITH THREE + ACRES OF YARD TO CUT, IT WOULD BE JUST WHAT I NEED. GOT IT UP AND RUNNING AND TRIED IT ON THE YARD. ON LEVEL GROUND IT DOES GREAT. GET IN SOME HEAVY GRASS WHERE THE YARD SLOPES, AND IT FALLS ON IT,S KNEES. IS THIS THE NATURE OF THESE TRACTORS OR DO HAVE I OTHER PROBLEMS?
