h transmission update and nuther question or two
Posted by tn terry t on December 11, 2005 at 19:14:03 from (205.188.117.73):
if you remember i had a transmission lock up and grinding feeling pto shaft well seems that someone had been in the main shaft cause yep you guessed it one of those little needle found its way between the constant mesh gear and the main shaftgear. bye the way none was missing from the bearing when i took it out anyway i have this ole heffer spread out all over the shop now so here is the questions . how much wear on the slider and running gears are exceptible before i need to replace them? these i have are all rounded appox. 3/16 inch so what you fellers think about ordering used gears sight-un seen? any kind of help is deeply appreciated terry t
