Re: C engine locked up
Posted by old on December 12, 2005 at 07:10:39 from (207.69.139.7):
In Reply to: C engine locked up posted by toomannycases on December 11, 2005 at 20:53:45:
As the others have said you need the water out before the tranny fluid. Also you should put tranny fluid in the other cylinders. After you get the water blown out of the cylinders, ya blow them all out then put tranny fluid in each cylinder and also pout a quart or so down the exhaust pipe to lube up the valves.
