Re: Finally Found a Tractor - Now I have some ques
Posted by Unreserved dick on December 12, 2005 at 09:22:34 from (4.228.126.129):
In Reply to: Finally Found a Tractor - Now I have some question posted by jmauss on December 11, 2005 at 13:05:10:
Probably the easiest and best way for you to get manuals for your 350U is to order them from Binder Books (.com); these are licensed reprints and are very good quality. If you order those available through this site, quality is probably going to be disappointing. You might want to get:
#1004022 International 350 Utility, etc. Operator's Manual
#TC-57A International 300 and 350 Utility Parts Manual ($43)
#GSS350USET Service Manual Set for 350 Utility ($75)
At a minimum, get the Operator's Manual.
Your existing 2-point hitch should allow you to use either 2-point or 3-points implements easily with the addition of conversion tongs which it sounds as though you don't have. They are available online from this site, follow the link. Personally I prefer the 2-point hitch using these adapters to the typical 3-point hitch found on small tractors because it's much easier in practice to use by simply backing the tractor into the implement.
You will probably want the tongs for 26" spacing. Your existing hitch should already have a place to attach a standard 3-point toplink on its rockshaft. The only thing you need to keep in mind with this setup is that the spacing on the implement must conform to the 26" standard spacing; watch out for implements with homemade 3-point hookups because the spacing may not be exactly what it should be.
Hope this helps. Don't be afraid to post any questions as you get sucked further into all this.
