Re: gas to diesel conversion
Posted by Bob M on December 12, 2005 at 10:20:08 from (151.190.254.108):
In Reply to: Re: gas to diesel conversion posted by Nat on December 12, 2005 at 05:30:06:
"An MD has the same bottom end as a gas M, so why couldn't the same thing be done to an H?"
Nat - Actually only the external dimensions of the M and MD block are the same. Internally they are very different (the MD has a heavier, 5 bearing crank in vs. a 3 bearing crank in the M, etc)
Regarding the H "factory diesel", most likely someone took a Continental diesel from a 350D and stuck it in an H. It would be a relatively straightforward engine swap.
