Re: No Shoes Follow Up
Posted by Bilko on December 12, 2005 at 15:54:22 from (24.11.93.251):
In Reply to: No Shoes Follow Up posted by Dellbertt on December 12, 2005 at 15:04:40:
Dellbertt,
I was having the same problem digging up my yard. I ran across a thread a couple days ago on another tractor site and found my answer. What I was told to do was take a 2inch or 3inch piece of pvc pipe cut it to length of the blade and then take the skill saw and make one cut length ways on the pipe and slip it over the blade edge. I was skeptical at first thinking it would not stay on because it doesn"t use any fastner just the spring in the pipe, or scape worth a darn. But I have used it four times now and wish I had found out sooner!!! Plus doesn"t wear the blade down and you can buy it for a couple bucks. Any questions let me know. Mike from MI
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
