Re: removing the crankshaft pulley on Super C
Posted by El Toro on December 13, 2005 at 04:08:24 from (152.163.101.13):
In Reply to: Re: removing the crankshaft pulley on Super C posted by Bob the billder on December 12, 2005 at 18:47:02:
If you have a cutting torch you can make one pretty quick. You can get the 3/4 allthread from
Home Depot. Get the 36" and have them saw it in half. They have the flat washers and the hex nuts. When you get ready to reinstall the pulley, place it in your over at 225 degrees and let it get thoroughly hot. Use your welder's gloves to handle it. Be sure to clean the crankshaft where this pulley is installed too.
You need to have the bolts on the timing gear cover loose until you get the pulley installed.
You need to inspect the hub on the pulley to make sure it doesn't have a groove worn from the old oil seal. If it does Chicago-Rawhide has speedi sleeves and seals to repair this problem. Hal
