Re: Storing Tractors in Historic Barn
Posted by PurdueAg on December 13, 2005 at 06:45:39 from (198.109.220.6):
In Reply to: Re: Storing Tractors in Historic Barn posted by Nat on December 13, 2005 at 05:00:47:
Hi Nat,
I'm not *that* dumb! There's no way I'm driving any of
my tractors in there until I am as sure as I can be that it's
safe to do so! I'm pretty cautious. I mainly just wanted
to know if there are people who do, and if the bank
barns were typically designed for such weight. I've
seen enough barns in the last couple of weeks to know
that there is a whole continuum of "decay states" in
these old barns. So, your points are very well taken,
and I appreciate the advice regarding contacting an
engineer.
The planks look to be about 2 inches thick (actual 2").
The beams look to be about 12" thick. The timbers and
beams look solid, but I did not examine all of them, and
I did not examine the entire length. I did notice that
there are some vertical supports that have been set in
metal tubes that are filled with cement.
With kind regards,
Tony
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
