Re: Super A Hydraulic System
Posted by CNKS on December 13, 2005 at 17:35:50 from (204.249.178.138):
In Reply to: Re: Super A Hydraulic System posted by Charles Houstons on December 13, 2005 at 06:21:46:
I think you replace the lines between the resevoir and pump. The attachment to the reservoir contains the valving for both the rockshaft and the remote. Ask again how to install, you will find a parts manual helpful.
