Re: I feel that itch coming on
Posted by Kelly C on December 14, 2005 at 06:59:18 from (63.171.43.140):
In Reply to: Re: I feel that itch coming on posted by Cory R. on December 14, 2005 at 04:01:20:
Actually the 300 is all back together. Just not running yet.
I got it to pop over with a shot of ether but then noticed that I had coolant leaking into the cylinders. I have it drained and need to pull the head. Maybe not tight enough or some thing else like a crack.
Will work on it at the same time as the 706.
