Re: Farmall B single front wheel bearing question
Posted by gene bender on December 14, 2005 at 07:06:25 from (66.43.221.81):
In Reply to: Farmall B single front wheel bearing question posted by chris schultz on December 13, 2005 at 15:01:14:
tHE PARTS MAN IS CORRECT BECAUSE THERE AINT ANY BEARING. Take it apart and get bushings made for the hubs mite have to get the axle turned also. What size tire does yours have? Rim will be either a 10 or 12
