Farmall 300 Hydraulic leak
Posted by Sam F. on December 15, 2005 at 08:38:03 from (209.209.106.123):
On a model 300, where the 2 hydraulic steel lines go into the pump below and in front of distributor, what kind of gasket or seal is used. Mine is leaking fluid from 1 of the bottom bolts. Part # and can dealer get them ?? Simple unbolt and replace ?? Thanks
