Re: C113 Engine Noise
Posted by Andrew Z on December 16, 2005 at 13:36:17 from (64.252.231.101):
In Reply to: C113 Engine Noise posted by Dixieland on December 16, 2005 at 13:16:24:
I would pull the cover off the Govener and see if one of the weights has fallen off or a broken pin or something that holds them in place. If it is that get a used weights or the whole unit. I checked how much one weight would be and its NUTS.
Good Luck
Andrew
