Re: Smokin' H
Posted by Steven@AZ on December 18, 2005 at 05:55:18 from (24.121.48.188):
In Reply to: Smokin' H posted by Eric Allen on December 17, 2005 at 23:46:40:
How much is a lot of blue smoke? Like a cloud that keeps the mosquitos away?
These old tractors will all throw some blue smoke when you start them because there are no valve seals. None, zip, zilch. They never came with valve seals.
Advice below is correct, do a compression check and get back to us with the results of dry vs. with oil in the cylinders (not a lot, just a couple squirts). If you don't have a compression tester you should be able to rent one for under $10 for the day, or buy one for around $25.
How is the oil pressure? If the oil pressure is good then you know the bearings are just fine and you might just need a new set of rings...
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
