Re: Smokin' H_I agree
Posted by Janicholson on December 18, 2005 at 06:47:31 from (66.173.50.118):
In Reply to: Smokin' H posted by Eric Allen on December 17, 2005 at 23:46:40:
The only thing to add is an additional test for valve guide wear. (and a cheap fix) If the engine smokes most after idling for a while, or after going down a hill in 5th with the throttle closed, then cleans up pretty much when being worked some, then guides may be the issue. High vacuum causes more oil to be drawn in past the loose guides. If this is the case, putting on Perfect circle valve seals (or even just umbrella seals) does not require removing the head. Tips Remove rocker shaft, leave pushrods in. Work on one cyl at a time. Put piston on TDC and lock engine in that position by putting in 5th and locking brakes. (keeps valves from falling into the cylinder if pressure is lost) Use a 3/4" deep socket and plastic hammer to rap the keeper downward on each valve to break them loose. Put shop air pressure in the cylinder through an old spark plug brazed to an air fitting. (keeps valves closed with retainers off) Use a tierod "pickle fork" and a piece of 5/16 chain to make a spring compressor to remove the keepers. Bolt the chain to holes used for rocker shaft. Don't use the rocker shaft bolts. Install the seals, and reassemble. The process takes as much time to organize as it does to do. JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
