Re: Front end loader from Int 414 - will it fit a
Posted by George 2 on December 18, 2005 at 08:14:02 from (216.46.141.114):
In Reply to: Front end loader from Int 414 - will it fit a 354? posted by Greg Beale on December 18, 2005 at 01:38:34:
The 1501 loader from a B414 will not fit a 354 because the rear mount is a bar across the loader mount and bolted to the top of the transmission housing. That same mount on the transmission housing is used to support the instrument panel on the 354. The later 1501 on the 434,444(UK), and the 1550 on the 354, 444(UK), and 384 will fit the 354. This loader mount at the rear on the side frame bolt mounts on the side of the clutch housing. Note that some B250, B275, and B414 tractors were later fitted with this later version of the 1501 loader and they would fit. In addition there is a different set of loader mounting frames for the American made 424 and 444 (US) tractors. Those won't fit either as the front mount is different. Note also that any of these 3 loader frames can be made to fit anything if you are willing to modify the mounting frames
