Re: H shifter removal
Posted by RustyFarmall on December 18, 2005 at 16:13:46 from (207.32.13.222):
In Reply to: H shifter removal posted by Guyzoo on December 18, 2005 at 15:51:21:
You need to look a little further down, underneath the bell shaped part, you will find two small plugs, directly across from each other. You can pry these plugs out and beneath them is a pin that just drives out. Once that pin is out you can just pick up on the shifter and lift it right out of there. Sometimes the plugs are already gone, and sometimes the pin has been replaced with a long bolt and nut.
